Pre and Post-Processing with HyperWorks
This section details the integration of AcuSolve with the industrially accepted pre and post-processing tools of HyperWorks.
AcuSolve is smoothly integrated with pre and post-processing HyperWorks products.
For example, traditional users of HyperMesh can prepare the model in HyperMesh and then can either export the input files for AcuSolve or launch the AcuSolve solver directly by clicking .
After the solution is obtained from AcuSolve, HyperWorks can be used for various post-processing applications. Although AcuSolve provides AcuProbe and AcuFieldView for post-processing, traditional users of HyperWorks can make use of HyperWorks post-processing tools. For example, AcuSolve .log files can be directly read from HyperView by clicking and then choosing the appropriate AcuSolve .log file.
HyperStudy is also integrated for AcuSolve. While performing a parametric study of the CFD simulation, HyperStudy can be used to its fullest advantage. HyperGraph can also be used with AcuSolve to visualize the graphical interpretation of the results. To do this you must convert the AcuSolve results into a tabular format using AcuTrans. In the AcuSolve command prompt use the command acuTrans –out .
