HyperStudy and MotionView
HyperStudy can be directly accessed from MotionView:
  • Select HyperStudy from the Applications menu.
When you open HyperStudy from within MotionView, you have direct access to the MDL database to perform design parameterization.
The following solvers are supported:
  • MotionSolve
  • ADAMS
  • Abaqus
All entities in the MDL model tree can be accessed for defining design variables. In addition, models can also be parameterized using a base input template derived from the ASCII solver input.
