MV Gfile Trans
Converts an .obj formatted file into an Altair G format file that can be used as file graphics in an MDL model.
From the Tools menu, select Custom Wizards > MV Gfile Trans to access the utility.
Figure 1. MV Gfile Trans Custom Wizard
Select file to translate Select the file that you want to translate.
Select output filename Select the output filename and the directory to which you want to save the file.
Translator options Choose from the options listed (optional).
MessageLog Displays the Message Log.
Back/Next Go to the previous or next window.
Finish After entering the source file and output file names, click Finish to create the file and exit the dialog.
