Manufacturing Solutions
Util Macro Menu
Util Macro Menu
Util Macro Menu
From the bottom of the Utility Menu, click Util and the following menu appears:
util_macro_menu
The Util macro menu contains these tools and shortcuts.
Tools
Scale
Scales entities uniformly or non-uniformly. See the Scale panel info below.
Isolate Surf
Isolates either an inner or an outer surface layer from a 3-D model. This macro works only on the surfaces attached to the selected surface. The other layer and thickness are then placed in a temp directory and masked.
MidSurface
Opens the Midsurface panel.
Edges
Equiv
Provides a shortcut to the edges subpanel and equivalence function selected.
Multi-Comp Equiv
Provides the Automesh panel – cleanup subpanel -- toggle function.
(Un)suppress
Provides a shortcut to the edit edges subpanel and (un)suppress function selected. See panel info below.
Surfaces
Spline
Provides a shortcut to the Spline panel, with the lines selector button highlighted and the mesh, keep surf option selected.
Drag
Provides a shortcut to the Drag panel, with the node list selector button highlighted and the mesh, keep surf option selected.
Spin
Provides a shortcut to the Spin panel, with the node list selector button highlighted and the mesh, keep surf option selected.
Ruled
Provides a shortcut to the Ruled Surface/Mesh panel, with the node list selector button highlighted and the mesh, keep surf option selected.
Sweep
Provides a shortcut to the Line Drag panel and  the drag geoms subpanel,  with the node list selector button highlighted and the mesh, w/o surf option selected.
Skin
Provides a shortcut to the Skin Surface/Mesh panel, with the line list selector button highlighted and the mesh, keep surf option selected.
Surface Edit
2 Node Cut
Provides a shortcut to the Surface Edit panel and the trim with nodes subpanel, with the two nodes option selected and the yellow nodes selector button highlighted.
Defeature
Provides a shortcut to the Geom panel and the pinholes subpanel, with the yellow surfs selector button highlighted.
Delete
Provides a shortcut to the Delete panel with the yellow surfs selector button highlighted.
Duplicates
Provides a shortcut to the edit edges subpanel and (un)suppress function selected. See panel info.
See also
Utility Menus
