Manufacturing Solutions
Friction Stir Welding Utility Menu
The Friction Stir Welding Utility menu lists options to import models into HyperMesh, create weld mesh, select and assign material properties, define and apply boundary conditions, define process conditions, and export data files to HyperXtrude. Options in the Utility menu fall into two categories:
shortcuts to native HyperMesh panels
TK popup menus.
fsw_macro_menu
Utils:
Clear Temp Nodes
Clear temporary nodes
Model Setup Tools:
Create Mesh
Create the model, assign materials, boundary conditions, and process parameters through a wizard.
Select Units
Choose the units used in modeling the problem
Material Data
Select materials from a material database and assign material properties to components. View viscosity/flow stress graphs for materials.
Boundary Conditions
Inspect/Setup BCs
View and assign boundary conditions on element faces.
Check Undefined BC
Identify external faces without loads.
Check Duplicate BC
Identify duplicate loads.
Process Data
Specify process control parameters.
Extract Points
Define solution-monitoring points. The HyperXtrude solver prints detailed solution history at these monitoring points.
Model Summary
Inspect summary data such as number of elements and loads.
Export Data
Export/Launch Solver
Start the HyperXtrude solver using the current model, an existing data deck, or a restart file.
See Also:
Select Units
Friction Stir Welding User's Guide
