Manufacturing Solutions
Select Units
Select Units
Select Units
The Select Units macro is the first macro to use when you build a new model. This macro sets the units of geometry, velocity, temperature, and stress. Additionally, the units for stress are used for pressure and traction.
When you update the units with this macro, values for boundary conditions and parameters are automatically converted.
