Manufacturing Solutions
HyperWeld
HyperWeld
HyperWeld
Manufacturing Solutions includes an interface with a HyperWeld user profile and FrictionStirWelding sub-profile. This interface provides tools to create the required data to set up and solve a friction stir welding problem.
Note: The FrictionStirWelding sub-profile shares the same solver with the HyperXtrude user profile. In addition to this online help,  a set of tutorials is available to learn the interface for the HyperXtrude solver.
Data Files
Data generated for a friction stir welding analysis is organized into .grf and .fsw or .tcl files:
.grf files
The.grf file contains the mesh, material data, boundary conditions, and other special data.
.fsw or .tcl files
The .fsw file, known as a parameter file or .tcl file, contains commands written in the TCL language to set process parameters and control the solver operations. This file can be saved with either a .fsw or .tcl extension.
Process-Driven GUI Features
Create Mesh
Create Weld mesh model
Assign materials to components
Assign boundary conditions
Assign process parameters
Material Database
Add/edit/delete materials
Graph flow stress/viscosity
Boundary Condition Editor
Create/delete boundary condition data
Create loads for each BC
Additional Tools
Edit process parameters
Edit extract points
Inspect model summary
Split tet4 to hex8
Data Import and Export
See Also:
Introduction to HyperXtrude
Friction Stir Welding User's Guide
