Manufacturing Solutions
Microstructure Predictions
One of the key benefits of HX-Forge solver is the ability to predict Microstructure. During hot deformation process, the billet may undergo recrystallization through any of the recrystallization mechanisms, namely, static, dynamic and meta-dynamic recrystallization. Dynamic recrystallization usually occurs during deformation where as static or meta-dynamic recrystallization takes place post deformation. In HX-forge solver, grain size is calculated as a post processing step using one of the above mentioned recrystallization mechanisms. Most commonly used Avrami type semi-empirical models that express grain size as functions of initial grain size, strain, strain rate and temperature are used in microstructure computations. These models are described below.
Dynamic Recrystallization Model:
The grain size during dynamic recrystallization is calculated using
micro_01
Dynamically recrystallized fraction is given by
micro_02
Where micro_03 is strain for 50% recrystallization and is given by
micro_04
And peak strain corresponds to maximum flow stress is given by
micro_05
The average grain size after dynamic recrystallization is calculated using
micro_06
Static Recrystallization Model:
The grain size during static recrystallization is calculated using
micro_07
Statically recrystallized fraction is given by
micro_08
where micro_09is time constant for 50% recrystallization and is given by
micro_10
The average grain size after static recrystallization is calculated using
micro_11
Meta-dynamic Recrystallization Model:
The grain size during meta-dynamic recrystallization is calculated using
micro_12
Meta-dynamically recrystallized fraction is given by
micro_13
where micro_14is time constant for 50% recrystallization and is given by
micro_15
The average grain size after meta-dynamic recrystallization is calculated using
micro_16
In the above expressions, micro_17are material coefficients
micro_18
Yield Strength Calculation:
In HX-Solver, yield strength is calculated using Hall-Petch equation
micro_19
In HX-Forge, although GUI to specify the data relevant to microstructure is not available at present (planned for future release), user can specify this data by manually editing the *.grf file. The data format required by HX-Forge solver is described below.
 BEGIN PROBLEMDATA
         MicrostructureData GSData  {
# Initial Grainsize in microns
InitialGrainSize         = 250
# Universal Gas Constant R in J/mol.K
UniversalGasConstant   = 8.314
GrainSizeModelType     = "MetadynamicRX"
MDRXModel           = "MDRX_Data"
YieldStrengthModelType  = "Hall_Petch"
YieldStrengthModel      = "Yield_Data"
 MDRXGrainSizeData MDRX_Data {
       A         = 0.0001
       a4        = 5.043E-09
       a7        = 4.85E+10
       b1        = 250
       b2        = 1
       c7        = 0.0
       h4        = 0.0
       h7        = 0.0
       n4        = -1.42
       n7        = -0.41
       m4        = -0.408
       m7        = -0.028
       Q2        = 0
       Q4        = 196000
       Q7        = -240000
       beta_mdrx = 0.693
       k_mdrx    = 1.0
YieldStrengthData Yield_Data {
sigma0  = 25.0
       ky    = 0.5
# sigma0 is in   MPa
# ky     is in   MN m^-3/2
END
The different input parameters in the above data packet for microstructure predictions are explained below:
MicrostructureData is a keyword used to represent the data that include details about the recrystallization model, yield strength model and the associated material coefficients.
InitialGrainSize:
Initial grain size should be prescribed in microns.
UniversalGasConstant:
Always  8.314 J/mol. K
GrainSizeModelType:
For this parameter, user specifies a character string correspond to one of the recrystallization models described above as the model for grain size calculations.
The allowed values and corresponding recrystallization models are given below:
GrainSizeModelType  = “StaticRX”        – Static Recrystallization Model
GrainSizeModelType  = “DynamicRX”      – Dynamic Recrystallization Model used
GrainSizeModelType  = “MetaDynamicRX”  – Meta-dynamic  Recrystallization Model
Once the GrainSizeModelType is set, user should specify the material coefficients data for the respective recrystallization model. In the above example, GrainSizeModelType is set as “MetadynamicRX”, hence the solver expects the user to specify MDRXModel and the material coefficients data required for this model MDRXGrainSizeData as a separate data packet.
Meta-dynamic  Recrystallization data example:
       A         = 0.0001
       a4        = 5.043E-09
       a7        = 4.85E+10
       b1        = 250
       b2        = 1
       c7        = 0.0
       h4        = 0.0
       h7        = 0.0
       n4        = -1.42
       n7        = -0.41
       m4        = -0.408
       m7        = -0.028
       Q2        = 0
       Q4        = 196000
       Q7        = -240000
       beta_mdrx = 0.693
       k_mdrx    = 1.0
Static Recrystallization data example:
SRXModel       = "SRX_Data"
                SRXGrainSizeData SRX_Data {
                             A       = 1000
                      a3       = 3.16
                      a6       = 678.0
                      b1       = 250
                      b2       = 1
                      c6       = 0.0
                      h3       = 0.0
                      h6       = 0.0
                      n3       = -0.75
                      n6       = 0.0
                      m3       = 0.0
                      m6       = 0.0
                      Q2       = 0
                      Q3       = 74826
                      Q6       = -31710
                      beta_srx = 0.0
                      k_srx    = 1.0
 Dynamic Recrystallization data example:
DRXModel       = "DRX_Data"
                DRXGrainSizeData DRX_Data {
                            a1       = 0
                      a2       = 0.0
                      a5       = 0.0
                      a8       = 8.26E09
                      c1       = 0.0
                      c5       = 0.0
c8       = 0.0
                      h1       = 0.0
                      h5       = 0.0
                      h8       =1.0
                   n1       = 0.0
                      n5       = 0.0
                      n8       = -0.420
                      m1       = 0.0
                   m5       =0.0
                   m8       = 0.046
                      Q1       = 0
                      Q5       =0.0
                      Q8       = 0.0
                      beta_drx = 0.0
                      k_drx    = 0.0
Yield Strength data example:
sigma0  = 25.0
             ky      = 0.5
# sigma0 is in   MPa
