Manufacturing Solutions
Die Module Panels
Die Module Panels
Die Module Panels
The following panels are available on the main page when the Die Module user profile is active.
Addendum
Binder
Color
Nodes
Delete
Lines
Line Design
Line Edit
Modify Addendum
Node Edit
Organize
Prep Geom
Rename
Section Edit
Temp Nodes
HyperMorph – modifies the main panel to display the HyperMorph Module
