HyperView PAM-CRASH 2G結果リーダー
サポートされる結果
データ名 結果タイプ Data Type Keyword 備考
構造
Displacement NODE VECTOR
Velocity NODE VECTOR
Pressure NODE VECTOR 接触圧、CTCPR
Max normal pressure NODE VECTOR 標準圧、CTCMP
Mass Increase Factor NODE SCALAR 質量増分、N5
Increased Mass NODE SCALAR 増加後の質量、N6
応力 ELEMENT TENSOR3-D SXYZ 3-D
Equivalent Plastic Strain ELEMENT SCALAR EPLE 3-D
Int. Energy Density ELEMENT SCALAR INED 3-D、2-D
HG Energy Density ELEMENT SCALAR HGED 3-D、2-D
Solid Aux ELEMENT SCALAR   3-D、最大6つの追加スカラー値
Max equiv. stress o. thickness ELEMENT SCALAR ESMA 2-D
Min equiv. stress o. thickness ELEMENT SCALAR ESMI 2-D
Max plastic strain o. thickness ELEMENT SCALAR EPMA 2-D
Min plastic strain o. thickness ELEMENT SCALAR EPMI 2-D
Moment local ELEMENT TENSOR2-D MXYZ 2-D
Membrane stress res. local ELEMENT TENSOR2-D NXYZ 2-D
Lower S strain ELEMENT TENSOR2-D EPSI_lower 2-D
Upper S strain ELEMENT TENSOR2-D EPSI_upper 2-D
Lower S stress ELEMENT TENSOR2-D SIGM_lower 2-D
Upper S stress ELEMENT TENSOR2-D SIGM_upper 2-D
Membrane stress ELEMENT TENSOR2-D SIGM_membrane 2-D
Membrane plastic strain ELEMENT SCALAR EPME 2-D
Membrane strain rate ELEMENT SCALAR STRA 2-D
Membrane VM Stress ELEMENT SCALAR ESME 2-D
Thickness ELEMENT SCALAR THIC 2-D
Thinning ELEMENT SCALAR THIN 2-D
Total Damage ELEMENT SCALAR DMG 2-D
Axial Force ELEMENT SCALAR FAXI 1-D
Transverse S shear force ELEMENT SCALAR FSSH 1-D
Transverse T shear force ELEMENT SCALAR FTSH 1-D
Torsion Moment ELEMENT SCALAR MTOR 1-D
S Moment at n1 ELEMENT SCALAR MSN1 1-D
T Moment at n1 ELEMENT SCALAR MTN1 1-D
S Moment at n2 ELEMENT SCALAR MSN2 1-D
T Moment at n2 ELEMENT SCALAR MTN2 1-D
Axial Elongation ELEMENT SCALAR DAXI 1-D
R Torsion angle ELEMENT SCALAR RTOR 1-D
S Bending rotation at n1 ELEMENT SCALAR RSN1 1-D
T Bending rotation at n1 ELEMENT SCALAR RTN1 1-D
S Bending rotation at n2 ELEMENT SCALAR RSN2 1-D
T Bending rotation at n2 ELEMENT SCALAR RTN2 1-D
Minimum Hill Stress ELEMENT SCALAR   コンポーネント
Maximum Hill Stress ELEMENT SCALAR   コンポーネント
Membrane Hill Stress ELEMENT SCALAR   コンポーネント
Distance to FLD ELEMENT SCALAR   コンポーネント
Wrinkle Criterion ELEMENT SCALAR   コンポーネント
Material Internal Energy ELEMENT SCALAR   コンポーネント
Material Kinetic Energy ELEMENT SCALAR   コンポーネント
Material Hourglass Energy ELEMENT SCALAR   コンポーネント
ビームコンポーネントの場合は曲げエネルギーを表します。
Bending Energy Density ELEMENT SCALAR   コンポーネント
Membrane Energy Density ELEMENT SCALAR   コンポーネント
Transverse Shear Energy Density ELEMENT SCALAR   コンポーネント
Material Equivalent Membrane Energy ELEMENT SCALAR   コンポーネント
注:
  • HyperViewリーダーは、Femzip ERF (HDF5)結果、femzipライブラリのバージョン6.1.3019をサポートします。
  • HyperViewは、DSYファイルとERFH5(HDF5)ファイルをサポートします。
  • ERHF5(HDF5)ファイルの読み取りは、WindowsプラットフォームとLinuxプラットフォームでのみサポートされています。
  • HyperViewとHyperGraphは同じERFH5結果リーダーを用いてERF(HDF5)結果をサポートします。2019年に、PAM-CRASH ERFリーダーは、モジュラー入力定義を使用したERF(HDF5)結果をサポートするように拡張されました。複数のモジュール間で共有する重複したIDを同じモデルの中で扱うことができるように、エンティティプールが導入されました。これらのエンティティは、それらのモジュールIDおよびその親エンティティのモジュールIDによって表されます。
  • HyperViewでは、THPファイルからモデルを読み取ることはできますが、結果は読み取ることができません。
  • PAM-CRASHのERF(HDF5)リーダーとDSYリーダーは、より新しいバージョンの結果ファイルを扱うことができるように拡張されています。
  • HyperViewでは、PAM-VIEWと同じ命名規則を使用します。
  • HyperViewでは、NT、LINUX、SGI、HP、SUN、IBM、FUJITSU、およびNECの各プラットフォーム上で作成されたファイルをサポートします。
  • HyperViewでは、PAM-CRASH 2G入力デックからモデルを読み取ることができます。
  • HyperViewでは、v11.00以前のバージョンのFEMZIPライブラリを使用して、PAM-CRASH 2Gのzip圧縮DSYファイルを読み取ることができます。
