Create Section and Material Properties
Use the CAD Properties tool to generate PSHELL properties and Beam properties as well as material solver realization.
  1. From the Marine ribbon, click the CAD Properties tool.
  2. Select parts.
    These parts should hold the following metadata:
    Plate_T
    Thickness value for panels parts
    Material
    Reference to a material entity
    BeamSection
    Reference to a beamsection entity for Stiffener Parts
  3. On the guide bar, click to define the material card image and how properties are updated and applied.
  4. On the guide bar, click one of the following:
    • - Save changes and stay in the tool
    • - Save changes and close the tool
    FE data is applied to your selection.
