Release Degrees of Freedom
Use the Stiffener Mesh: Pins tool to edit and release degrees of freedom.
You can select a single element at a time and review or edit the released degrees of freedom at node A and node B.
  1. From the Marine ribbon, click the Stiffener Mesh > Pins tool.
  2. Select a beam element.
  3. Move the node A and node B microdialogs so that they are both visible.
  4. Click the appropriate translate or rotate button depending on which axis you would like to affect.
