Beam Sections
Use the Beam Sections tool to create and edit standard beam sections, cross beam sections, and HyperBeam sketches.
The beam section tools used in the Marine ribbon are the same as the beam section tools in the Mesh ribbon.
For details on each tool, see the 1D Mesh chapter.
