HyperView Radioss Results Reader
Supported Results
Data Name Result Type Data Type
Vectors
Displacement NODE VECTOR
Contact Forces NODE VECTOR
Velocity NODE VECTOR
Acceleration NODE VECTOR
Displacements (from File) NODE VECTOR
External Forces NODE VECTOR
Internal Forces NODE VECTOR
Sect. RBY Moments NODE VECTOR
Sect RBY, Wall F NODE VECTOR
Nodal Scalars
Grid Point Stress NODE SCALAR
Node Mass NODE SCALAR
Mass Change NODE SCALAR
Time Step NODE SCALAR
Elemental Scalars ( for 2-D and 3-D elements only
Plastic Strain ELEMENT SCALAR
von Mises ELEMENT SCALAR
Specific Energy ELEMENT SCALAR
Hourglass Energy ELEMENT SCALAR
Density ELEMENT SCALAR
Mass ELEMENT SCALAR
Pressure ELEMENT SCALAR
Damage 1 ELEMENT SCALAR
Stress X ELEMENT SCALAR
Stress Y ELEMENT SCALAR
Stress XY ELEMENT SCALAR
Stress YZ ELEMENT SCALAR
Stress ZX ELEMENT SCALAR
Tensors (for 2-D elements)
Stress (membrane) ELEMENT TENSOR2-D
Stress (upper) ELEMENT TENSOR2-D
Stress (lower) ELEMENT TENSOR2-D
Strain (membrane) ELEMENT TENSOR2-D
Strain (upper) ELEMENT TENSOR2-D
Strain (lower) ELEMENT TENSOR2-D
Tensors (for 3-D elements)
Stress ELEMENT TENSOR3-D
Damage ELEMENT TENSOR3-D
Note:
  • A files from Radioss 41, 44, 51, 90, 110, and 120 are supported.
  • A files written in Radioss 44 and Radioss 51 format are supported.
  • A Files from Radioss 31 are not supported.
  • 1D element results (both scalar and torsion) are not supported.
  • All tensor results (2D and 3D) should be viewed in the Element Result System.
  • Plastic strain across thickness is supported.
  • A files from RAD2NOISE tool are supported.
  • HyperView can read zipped A00 files of Radioss using FEMZIP libraries v11.27 or older.
  • Ply systems for orthotropic/composite shells and solids are supported. You can review systems for individual plies(layers) through the Systems Review dialog. You can also transform stresses and strains from an elemental or global system to a ply system. To review these systems and use them for transformations, make sure that the datatype PHI is written to the Radioss animation file and the advanced result-math template is used to load the results in HyperView.
