Spin Geometry
Spin surfaces, nodes, or lines around a defined axis.
From the Geometry ribbon, Drag/Spin tool group, click the Spin
tool.
- Optional:
On the guide bar, click
to define additional options.
- Choose between Surfaces, Nodes, and Lines using the guide bar selector.
- Select surfaces/nodes/lines in the modeling window.
- Click Spin Axis on the guide bar.
- Left-click to place the axis.
Spin your selection by dragging the slider or entering an angle in the microdialog.
Tip: Click
in the microdialog to define the direction of the spin axis using the Vector tool. Once a direction has been defined, press Esc.
On the guide bar, click one of the following:
- Save changes and stay in the tool
- Save changes and close the tool
- Exit the tool without saving changes
