Beamsections
Beamsection entities store 1D beam cross-section data.
Beamsections can be created from geometry, elements, or from solver standard sections, that is, I-Sections, H-Sections, and so on.
All sections can be created and modified in HyperBeam. Generic sections and Standard sections can also be created in the Model Browser and modified in the Entity Editor.
The default section type and attribute values assigned to beam section vary based on solver interface.
On import, each 1D beam property card within a solver deck is automatically imported as a beamsection entity and a property entity with associated beamsection. The beamsection entity holds the 1D beam section data (A, I, and so on..., and/or Dimensions) and is associated to the property entity which has a 1D property card image. The beamsection association to a property is what transfers the 1D section data to the 1D property solver card for export. Editing of all 1D beam section data is accomplished through HyperBeam.
Generic Sections
Generic sections define sections without defining actual cross-section geometry. Areas, inertias, centroids, and other coefficients are supported directly through spreadsheet data entry of values.
Shell Sections
Shell sections define thin cross-sections with geometric lines or 1D elements. Once the cross-section is created, it can be further edited in HyperBeam.
Solid Sections
Solid sections to define solid cross-sections with surfaces, lines that form a closed loop, or 2D elements. Once the cross-section is created it can be further edited in HyperBeam.
Standard Sections
Standard sections to define solver supported cross-sections. Each supported solver interface has a library of supported solver cross-sections. For standards sections, only the dimensions of the section are necessary as input.
Figure 3.
