Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply
shapes for subsequent design optimization studies.
Create weld points at a predefined pitch distance so that the model build process can continue without the need to
wait for the published weld data from CAD. Autopitch is useful when working with elements, not geometry.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating
the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Restriction: Available in Abaqus, Nastran, and OptiStruct.
Creates RBE2 (Nastran/OptiStruct)
or KINCOUP (Abaqus) elements for the head and the body.
There are two individual RBE2/KINCOUP elements at the head of the connection, one to
connect to the inner row of nodes, the other to connect to the washer layer nodes. The
RBE2/KINCOUP head element that connects to the washer layer nodes only connects to every
other node on the washer layer. The connector location can either be on the edge of the
hole, center of the hole, midpoint in between the two holes or on the second row of
nodes which form the washer layer.
