Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply
shapes for subsequent design optimization studies.
Create weld points at a predefined pitch distance so that the model build process can continue without the need to
wait for the published weld data from CAD. Autopitch is useful when working with elements, not geometry.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating
the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
This realization creates rows of HEXA elements for the body. The HEXA elements project
and connect to the adjoining shell/solid elements by touching them.
Note: Uses the
default parameters, material thickness lookup table, and material strength lookup
table from the weld_config.ini config file to set the default
attributes for the created MATL100 material.
The adhesive - shell gap exists in exactly the same configuration with the following
additional names:
HC glue mastic sealer
HC glue spot sealer
HC glue glass adhesive
This is in order to keep the realization names from HyperCrash.
The realization uses the prop_dyna_matnum_seamarea.tcl post
script. Figure 1.
