Delete a Tracking System
  1. From the Create tools, select Create > Tracking Systems.
  2. Select a tracking system from the Tracking Systems list.
    Note: Multiple tracking systems can also be selected.
  3. Delete the tracking system(s) using one of the following methods.
    • Click Delete (located at the bottom of the panel).
    • Press the Delete key on the keyboard.
    The tracking system is removed from the list.
