Access the Context Menu
  1. From the Create tools, select Create > Tracking Systems.
  2. From the Tracking panel, right-click anywhere within the Tracking Systems list.
    The context menu is displayed.
  3. Click on one of the available options.
    Delete Deletes the selected tracking system(s) from the list.
    Rename Displays the Rename dialog, which allows you to rename the selected tracking system.
    Make Current Allows you to select which tracking system will be activated and displayed in the modeling window. This option performs the same action as clicking the radio button "on" next to a tracking system.
