Delete a Set
  1. From the Create tools, select Create > Sets.
  2. From the Set panel, select a set/group.
    Tip: Multiple sets can be selected to be deleted.
  3. Delete the set(s) using one of the following methods.
    • Click Delete (located at the bottom of the panel).
    • Press the Delete key on the keyboard.
    The selected set is removed from the list.
