Delete a Note
To delete a note from the Notes panel:
  1. From the Annotate tools, click the Notes tool.
  2. Select a note from the Notes list.
  3. Delete the note using one of the following methods.
    • Click Delete (located at the bottom of the panel).
    • Press the Delete key on the keyboard.
    The note is removed from the list and the modeling window.
