Add a Field Name to a Note
From the Annotate tools, click the Notes tool.
Figure 1. - From the Notes panel, select a note from the Notes list.
From the Field names drop-down menu, select fields to be used in a Templex
expression.
Tip: You can also enter a Templex expression directly into the Description box.
Click Insert Field.
Tip: Press Enter to create a new line. There is no limit to the number of lines a note can contain. Click the expansion button, , to enlarge the Description box.
Click Apply to display the text in the note box or
update existing text.
Note: Templex statements entered in the Description box are evaluated when you click Apply. If an entity is referenced that is not available, it will be stated in the note. An 'if-then' statement can be used to remedy such a situation.
