Access the Context Menu
From the Annotate tools, click the Notes tool.
From the Notes panel, right-click anywhere within the Notes list.
The context menu is displayed.
Click on one of the available options.
Delete Deletes the selected note(s) from the list. Rename Displays the Rename dialog, which allows you to rename the selected note. Show Displays the selected note(s) in the modeling window and activates the corresponding check box(s). Hide Hides the selected note(s) in the modeling window and deactivates the corresponding check box(s). Copy Creates a new note with a new label but the same settings as the selected note.
