Attach a Note to an Entity
From the Annotate tools, click the Notes tool.
Figure 1. - From the Notes panel, select a note in the Notes list.
- Under Attach to, select Entity.
Select an entity from the input collector menu.
- Node
- Element
- Component
- System
Select the entity.
- Click the input collector (Node, Element, Component, or System) and select By ID.
- Pick an entity (node, element, component, or system) directly from the model in the modeling window.
Click Apply.
The note is attached to the selected entity.
