Measure Templex Expressions
Learn more about measure Templex expressions in HyperView.
Evaluating Expressions
The following methods can be used:
  • Tcl Console
  • HyperView Notes
  • TextView
Non-Grouped Measures Expression Type
The expression below will return the default x vector for the measure item specified by item_index.
"p" <page_id> "w" <window_id> "measure" <measure_id> . item_index . x_option . y_option . "x"
For example, p1w1measure3.7.0.3.x will return the x vector (time in this case) for item 7 in measure group 3.
Where:
Page ID = 1
Window ID = 1
Measure ID = 3
Item Index = 7
X Option = 0 (Default)
Y Option = 3 (Magnitude for a Distance Between measure, for example)
In addition, the expression below will return the y vector specified by y_option for the measure item specified by item_index.
"p" <page_id> "w" <window_id> "measure" <measure_id> . item_index . x_option . y_option . "y"
For example, p1w1measure3.7.0.3.y will return the magnitude values for item 7 in measure group 3, across all time steps.
Where:
Page ID = 1
Window ID = 1
Measure ID = 3
Item Index = 7
Note: The x_option must always be zero.
The expression below will return the x vector specified by x_option for all of the items in a measure group.
"p" <page_id> "w" <window_id> "measure" <measure_id> . "all" . x_option . y_option . "x"
For example, p1w1measure3.all.2.3.x will return the Y coordinate values of all items in measure group 3, at a particular time step.
Where:
Page ID = 1
Window ID = 1
Measure ID = 3
X Option = 2 (Y Coordinate)
Y Option = 3 (Magnitude)
In addition, the expression below will return the y vector specified by y_option for all of the items in a measure group.
"p" <page_id> "w" <window_id> "measure" <measure_id> . "all" . x_option . y_option . "y"
For example, p1w1measure3.all.2.3.y will return the magnitude values of all items in measure group 3, at a particular time step.
Where:
Page ID = 1
Window ID = 1
Measure ID = 3
Note: In this example the keyword "all" is used for the item index, in order to indicate that the returned values are for all items in the measure group.
Measure Values at a Particular Time Step
The expression below will return all values for measure item specified by item_idx, at a particular timestep.
"p" <page_id> "w" <window_id> "measure" <measure_id> . item_idx . "vals"
For example, p1w1measure3.2.vals will return all values (for example: X, Y, Z and Magnitude for a Distance Between measure or X, Y, Z for Position measures) for measure item 2 in measure group 3.
Where:
Page ID = 1
Window ID = 1
Measure ID = 3
Item Index = 2
Min Values
The expression below will return the least value (minimum) across all time steps and measure items, for the given x and y options.
"p" <page_id> "w" <window_id> "measure" <measure_id> . x_option_idx . y_option_idx . "min"
Max Values
The expression below will return the greatest value (maximum) across all time steps and measure items, for the given x and y options.
"p" <page_id> "w" <window_id> "measure" <measure_id> . x_option_idx . y_option_idx . "max"
Extreme Values
The expression below will return the greatest absolute value (extreme) across all time steps and measure items, for the given x and y options.
"p" <page_id> "w" <window_id> "measure" <measure_id> . x_option_idx . y_option_idx . "extreme"
For example, p1w1measure3.0.3.min will return the least value of magnitude across all measure items and time steps, the time/frequency at which this value is attained, and the time step/frame at which this value is attained. Similarly max will return the largest value, and extreme will return the largest absolute value.
Where:
Page ID = 1
Window ID = 1
Measure Group = 3
X Option = 0
Y Option = 3
Measure Group IDs
The following expression can be used to return all of the IDs in the measure group specified by measure_id:
"p" <page_id> "w" <window_id> "measure" <measure_id> . "ids"
For example, p1w1measure3.ids would be used to return the IDs of all measure items in measure group 3.
Where:
Page ID = 1
Window ID = 1
Measure Group = 3
Measure Group Label
The following expression can be used to return the label for the measure group specified by measure_id:
"p" <page_id> "w" <window_id> "measure" <measure_id> . "label"
For example, p1w1measure3.label would be used to return the label for measure group 3.
Where:
Page ID = 1
Window ID = 1
Measure Group = 3
Measure Options
The tables below contain the expressions for the measure options currently available in HyperView:
Distance Between, Incremental Distance, and Relative Displacement
Val X Option Y Option
0 Default (time, frequency) X Coordinate
1 X Coordinate Y Coordinate
2 Y Coordinate Z Coordinate
3 Z Coordinate Magnitude
4 Entity ID -
5 Distance -
Position
3 Z Coordinate -
4 Entity ID -
5 Distance -
Angle Between, Incremental Angle, and Relative Angle
0 Default (time, frequency) X Projection
1 X Coordinate Y Projection
2 Y Coordinate Z Projection
3 Z Coordinate True Angle
4 Entity ID -
5 Distance -
Yaw Pitch Roll
0 Default (time, frequency) Yaw
1 X Coordinate Pitch
2 Y Coordinate Roll
3 Z Coordinate -
4 Entity ID -
5 Distance -
Node Path, Nodal Contour, Elemental Contour, and Component Contour
0 Default (time, frequency) Value in the case of a single layer plot.
Bottom value in the case of a top/bottom plot.
1 X Coordinate Top value in the case of a top/bottom plot.
1mn(101, 102, etc.) - Value in the case of a single layer plot.
Bottom corner value in the case of a top/bottom plot, where mn is the corner node index number.
2 Y Coordinate -
2mn(101, 102, etc.) - Top corner value in the case of a top/bottom plot, where mn is the corner node index number.
3 Z Coordinate -
4 Entity ID -
5 Distance -
Notes
Any invalid expression will return “N/A”.
