Access the Context Menu
From the Home tools, click the Measure
tool.
From the Measure panel, right-click anywhere within the Measure Groups
list.
The context menu is displayed.
Click on one of the available options.
Delete Deletes the selected measure group(s) from the list. Rename Displays the Rename dialog, which allows you to rename the selected measure group. Show Displays the selected measure group(s) in the modeling window and activates the corresponding check box(s). Hide Hides the selected measure group(s) in the modeling window and deactivates the corresponding check box(s).
