Load Results Only
  1. From the Load Model panel, activate the Load results check box.
  2. If necessary, deactivate the Load model check box.
  3. Click the file browser button, , next to Load results and select a results file.
  4. Click Apply.
    The results file is loaded and applied to the current model specified. A results table is created for post-processing.
    Note: To change the specified current model, right-click on the name of the model file in the Results browser that you would like to set as the current model, and select Make Current from the context menu.
