Load a Model and Multiple Results from Different Files
  1. From the Load Model panel, activate the Load model and Load results check boxes.
  2. Click the file browser button, , next to Load model and select an animation file.
  3. Click the Add multiple result file icon, , located to the right of the Load results to open the Result File List dialog.
  4. Click the Add result file button, , to open the Load Results Files dialog.
  5. Select the desired result files using Ctrl + left click or Shift + left click, and click Open.
  6. If necessary, repeat Steps #4 and #5 to add more files.
  7. Click OK to exit the Result File List dialog.
  8. Click Apply.
    The model and the selected result files are loaded. A model content table and results table is created for post-processing.
