Load a Results File Containing Multiple Blocks
  1. From the Load Model panel, activate the Load model and Load results check boxes.
  2. Click the file browser button, , next to Load model and select an animation file.
  3. Click the file browser button, , next to Load results and select a results file.
  4. Click Apply. If the model contains more than one data block, you will be prompted to select the desired block.
    The model is loaded. A model content table and results table is created for post-processing.
