Anchor 2D Image Planes
The Anchor sub-tab allows you to select or change the location of the image plane relative to the modeling window.
  1. From the 2D Image Plane tab, click the Anchor sub-tab.
  2. Click one of the following icons to display the image in the location specified:
    Option Description
    Upper left corner of the modeling window.
    Upper right corner of the modeling window.
    Lower left corner of the modeling window.
    Lower right corner of the modeling window.
    The center of the modeling window.
  3. Optional: Click the Reset button to return the image/video in the modeling window to the state when it was originally loaded.
