2D Image Planes
The 2D Image Plane tool is primarily used for displaying static images and videos in the foreground or background of the graphics window.
The image planes can be stacked on top of each other, or against the model. To accommodate multiple media files in the graphics to be clearly visible, the 2D image planes can be resized and positioned in the graphics area. Various image processing filters and transparency settings allow you to adjust the media visibility to achieve a desired effect. In addition, an image plane can be tied to a model, so that any tracking system based deformations are considered on the media as well. The tracking mode is extended to reference points on the video as well, so that the image plane's relative position to the model is maintained. See the Model tab section for additional details.
