Crop Image Planes
The Crop tool allows you to crop an image so that only a desired portion of the media can be seen in the modeling window. The content that is displayed in the image plane is controlled by what is cropped.
  1. From the Image Plane tab, click the Crop icon .
    The crop tool is activated inside the Image Plane viewing area.
  2. Use your mouse to select the crop area (a rectangle which defines what part of the image you want to keep).
    The image in the modeling window will be updated immediately upon release of the mouse button, however the image in the Image Plane viewing area will remain unchanged.
    Note: Right-clicking on the Crop icon resets the crop tool and draws the full picture in the image plane.
  3. Click the Crop icon again to deactivate the Crop tool.
