Create a Vector Plot
The Display controls portion of the tab contains sub-tabs which allow you to control the presentation of the results/plot. The Plot sub-tab allows you to create a vector plot and turn on/off the display of various attributes.
  1. From the FBD tab, click the Plot sub-tab.
  2. Activate the coordinate check box(es) to display the corresponding axis (or axes) for Forces.
    • X, Y, Z
    • X+Y, Y+Z, Z+X
    • X+Y+Z (default)
  3. Activate the coordinate check box(es) to display the corresponding axis (or axes) for Moments.
    • X, Y, Z
    • X+Y, Y+Z, Z+X
    • X+Y+Z (default)
  4. Activate the Show values option to display the values at the tip of the vector.
  5. Activate the Label prefix option to display the label prefix of the vector.
