Delete Cached Results
The Cache button automatically changes to Delete cache whenever the result information matches the currently contoured result and the result has been previously cached.
HyperView will hold the cached data until it is deleted.
Note: Cached results are automatically deleted whenever the active subcase is changed or a currently active derived subcase is modified, a new session is started, or a model is deleted.
  1. Delete the internal cache of the active contour result using one of the following methods.
    • From the Contour panel panel, click Delete cache.
    • Right-click on the browser data item and select Delete from the context menu.
  2. To delete all of cached results simultaneously, right-click on the Cached results folder in the browser and select Delete from the context menu.
