Model Info
The Model Info dialog displays general information and statistics about your model.
After setting the current model, you can view the model properties by right-clicking anywhere within the Results Browser and selecting Model Info from the context menu.
General Tab
Displays the model label, and the model and results file names, locations, and reader types.
If the path of the file is too long to fit in the File name field, place your cursor over the field and bubble help will display the full path of the file.
You can change the name of the model by entering in a new name directly in the Label field.
Statistics Tab
Displays the number and type of entities contained in the model, the number of result simulations, the result math template used to load the files, and the reader options for both the model and the results.
