2D Roads
POLY_LINE
A piece-wise linear description of the road profile. Profiles for the left and right tracks are independent.
The [PARAMETERS] block in ROAD_TYPE = poly_line must have a sub-block (XZ_DATA). This sub-block consists of 3 columns, of which column 1 is a set of x-values in ascending order, and columns 2 and 3 are sets of z-values for left and right tracks. Note the X value is the wheel center in the X-Y plane of the road in the road reference marker.
An example of how a [PARAMETERS] block is represented, is shown below:
$--------------------------------------------------MODEL
[MODEL]
 METHOD		= '2D'
 ROAD_TYPE          = 'poly_line'
$--------------------------------------------------PARAMETERS
[PARAMETERS]
 OFFSET                      =   0
 ROTATION_ANGLE_XY_PLANE     = 180
 MU				= 1.0
(XZ_DATA)
    0    0    0
  900    0    0
 1000  100  100
 1020 -100 -100
 1030 -100 -100
 1031   50   50
 1040  100  100
 1140    0    0
 1240    0    0
FLAT
A Flat road.
$---------------------------------------------------MODEL
[MODEL]
 METHOD             = '2D'
ROAD_TYPE           = 'flat'
Note: No further parameters are required if ROAD_TYPE = flat.
POT_HOLE
A single pothole of rectangular shape.
[PARAMETERS] data for the Pothole road-type is shown below:
Parameter Description
depth Depth of the pothole.
start Start of the pothole.
length Length of the pothole.
If a positive value is given to “depth”, it will act as a bump.
$----------------------------------------------MODEL
[MODEL]
 METHOD     = '2D'
 ROAD_TYPE  = 'pot_hole'
 DEPTH                   = 50
 START                   = 1000
 LENGTH                  = 200
 DIRECTION               = 0.0
