Predefined Paths
[FEEDFORWARD_STEERING]
TAG = 'FEEDFORWARD'
LOOK_AHEAD_TIME = 0.5
PATH = 'PREDEFINED'
BLOCK = ‘PATH'
INTEGRATION_STEP_SIZE = 0.01
[PATH]
TYPE = 'CONSTANT_RADIUS'
RADIUS = 40
INITIAL_STRAIGHT = 10
ENTRY_ANGLE = 0.39
The vehicle follows the path as shown in the figure below:
[CONSTANT RADIUS]
TYPE Attr - string REQUIRED
<CONSTANT_RADIUS>
RADIUS Attr - real REQUIRED
Radius of the circle.
INITIAL_STRAIGHT Attr - real REQUIRED
Length of the initial straight before entering the turn.
TURN Attr - string OPTIONAL
LEFT
Vehicle turns to the left.
RIGHT (Default)
Vehicle turns to the right.
Similarly,
[PATH]
TYPE = 'SLALOM'
NUMBER_OF_CONES = 3
DESIRED_CG_LATERAL_DISP = 3
CONE_SPACING = 50
RECOVERY_LENGTH = 20
INITIAL_STRAIGHT = 20
[SLALOM]
TYPE Attr - String REQUIRED
<SLALOM>
NUMBER_OF_CONES Attr - int REQUIRED
Number of cones.
DESIRED_CG_LATERAL_DISP Attr - real REQUIRED
Desired CG lateral displacement.
CONE_SPACING Attr - real REQUIRED
Distance between adjacent cones.
Straight section before entering slalom.
RECOVERY_LENGTH Attr - real REQUIRED
Straight section after completing slalom.
ATTACK_DIRECTION Attr - String OPTIONAL
  • First cone if attacked from the specified direction.
  • Default is RIGHT.
Path as sequence of straights and arcs:
[FF_STEER_CONTROLLER]
TAG                     = 'FEEDFORWARD'
PATH                    = 'SEQUENCE_OF_ST_CRV'
BLOCK                   = 'PATH'
INTEGRATION_STEP_SIZE   = 0.010000
AGGRESSIVE              = 'TRUE'
[PATH]
{KEY        PAR0              PAR1}
'ST'        20.000000         0.000000
'ARC'       40.000000        -6.283184
This creates a path that is sequence of a straight (20 m) and arc (Radius 40 m, Angle 6.283184 rad. clockwise).
Figure 3.
[PATH]
{KEY        PAR0              PAR1}
'ST'        17.033191         0.000000
'ARC'       20.000000         -0.148890
'ST'        17.240436         0.000000
'ARC'       20.000000         0.148890
Figure 4.
