View new features for HyperWorks 2021.
Set up your sessions in HyperWorks and create report templates.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
HyperMesh composites modelings.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
MotionView is a general pre-processor for Multi-body Dynamics.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
From the Preferences menu, you can access the Options dialog.
This section describes how to build events in the full vehicle model with Altair Driver. The new event user interface is supported only for models with Altair Driver. The interface exports .adf and .xml files and submits them to MotionSolve. Files can be edited or updated in the Event Editor. Eighteen event types are supported.
This section describes all of the full vehicle events currently supported with Altair Driver. It also describes all of the events and their parameters.
The Altair Driver is a set of MotionView models and libraries that allows MotionView users to control and script vehicle events.
Controllers form the core of the driver. The Controller Library has various basic controllers its arsenal to calculate different driver outputs.
Open-loop controllers define vehicle inputs directly without feedback (for example, steering wheel angle vs. time).
Closed-loop controllers use vehicle responses (for example, speed, position, yaw rate, etc.) as feedback to determine the vehicle inputs needed to match a desired vehicle response, such as following a demand lean profile (for two wheelers) or a path.
Similar to the Feed-forward throttle and brake controllers, the steering feed-forward controller predicts the states of the vehicle after look ahead time or look ahead distance. Using a prediction point and defined path, it tries to minimize lateral error by applying a steering angle.
Lean angle profile controller for two wheelers employ a PID control to control the lean of a two-wheeler by applying steering angle.
Feedforward controller for two wheelers consisting of two cascaded controllers. The Feedforward control to provide demand lean to follow the path and the Feedback controller to follow the demand lean through steering output.
Driver can be loaded using the Model Wizard of MDLLIB when the Full Vehicle with Driver option is chosen. Driver has some special requirements to interface with the vehicle model. These requirements are resolved automatically if the vehicle model is built using the Full vehicle with advanced driver option in the Model Wizard in MDLLIB.
Driver uses the Altair Driver File (ADF) to access all the event parameters in the Solver.
Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
ON THIS PAGE
ON THIS PAGE
