Remove Objectives and Constraints
Existing Objectives and Constraints can be removed from the study by deleting them from the wizard.
To delete Objectives and Constraints, select the desired Objective (or Constraint) from the list and click the Delete button.
Note:
  • If a Response Variable is deleted, the corresponding objective and constraint (which uses the RV) will automatically be deleted.
  • If a Response Variable is suppressed, the corresponding objective and constraint (which uses the RV) will automatically be greyed out and it will not be used for the study (see below).
