Activate and Deactivate Model Entities
Entities in a system or analysis can be activated or deactivated from the model using the Browser Context-Sensitive Menu.
Right-click on the entity in the Project Browser and select Activate or Deactivate to define whether or not the entity contributes to the model.
Note: Deactivated entities will not be included when the solver file is written out.
When the Joint or Bushing panel is accessed, the I and J markers created for the joint or bushing are displayed graphically. The marker display is turned off as you exit the panel.
