Model File Management
Open and save model files, import/export models, and import/export a solver deck.
View new features for HyperWorks 2021.
Set up your sessions in HyperWorks and create report templates.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
HyperMesh composites modelings.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
MotionView is a general pre-processor for Multi-body Dynamics.
A multibody system study generally involves the following broad steps. The following sections give a brief introduction on using MotionView and the related HyperWorks products to conduct such a study:
MBD model files are files written using the Model Definition Language (MDL). These model files (*.mdl) can then be opened and saved in MotionView.
The import feature facilitates reading in systems from the wizard library, or the MDL data statements (properties), or a combination of the two using an MDL file. The export feature facilitates exporting wizard selection choices in the existing model and/or the MDL data statements (properties), or a combination of the two into an MDL file.
Learn more about MotionView model entities.
MotionView supports and encourages a modular model building approach. Different entities can be aggregated into containers, thereby arranging a model into a collection of different assemblies or sub-systems.
A collector is a yellow button on a panel that enables you to select an entity type either graphically or from the topics/motionview/collectors_select_entity_dialog_r.html.
Explore data entry in MotionView.
The expression builder allows you to enter expressions in text boxes without extensive typing and memorization. It can be used to construct mathematical expressions that are a function of the model parameters.
MotionView contains an implicit variable called SolverMode. In MDL, SolverMode can be used in an "if" context to define topology (include Templex templates). MotionView retains the "if" result for both cases so that when you toggle the solver type, the associated text becomes active within the user interface.
The Select an "Entity" dialog allows you to change the entity in a collector.
Batch mode allows you to generate a solver input model file from an MDL model file and run the solver job without starting the MotionView user interface.
The Export Data dialog allows you to export your data to an Excel or text file.
The Data Summary dialog displays model data in a table.
Coordinate systems in MotionView can be oriented using a variety of methods.
Implicit graphics can be displayed for all applicable entities, allowing you to visualize their location and orientation.
Check Model searches for unresolved references and invalid data in the model. If errors in the model are detected, it is reported in the message window that is displayed when the check is completed.
The Create Deformable Surface From FEM macro enables you to quickly create a matrix of explicit markers to be used in defining a deformable surface.
Explore the various panels and tools in MotionView.
The Command Sets panel allows you to create command sets for the solver-command file. The command sets for a model are order dependent, since they define the contents of the solver command file.
Use the Forms tool to edit general data entry forms.
Use the Deformable Curves tool to create and edit deformable curves.
MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multi-body dynamics models.
From the Preferences menu, you can access the Options dialog.
Reference material for the HyperWorks Desktop scripting interface which is a set of Tcl/Tk commands.
ON THIS PAGE
ON THIS PAGE
