Notes View
Notes view can be switched on by clicking the Notes icon, , in the Media Browser.
The Notes view filters the notes from all pages and windows in the current session and displays them in the respective hierarchy, with notes and its parent entities, such as window and page, as shown below.
Clicking on a note displays the note's properties in the Properties Table.
Similar to the Movies view, the Notes view also offers features such as a search and selection bar.
When you select one or multiple notes in the browser by the usual selection methods, you can edit the properties of the selected entities in the Properties Table, as shown above.
Standard
Label
The name of the note.
Visibility
Displays the note in the media window. Clear the check box to hide the note.
Text
The note text or Templex expression in the note.
Attach To
Select where the note will be attached. Options include Window and View.
Display
Font Settings
Click in this field to display the Font Selector dialog. From there, you can change the font type, style, and size.
Alignment
Text can be left-aligned, right-aligned, or centered in a note box by selecting the corresponding drop-down menu item. Text alignment is updated automatically.
Border Thickness
Determines the line thickness of the note's border. Select one of four line thickness styles from the drop-down menu to change the border.
Border Color
Click the color palette to edit the note's border color.
