Create a Marker
  1. From MediaView, select File > Open > Media to open a .avi file.
  2. From the Marker Tracing panel, click Add to add a marker.
  3. Click a pixel on the screen. Choose something with a high contrast to neighboring pixels, for example, corners or CG markers are good choices.
  4. Click Apply.
    MediaView determines the location of the markers during the movement of the video and locks their pixel location along with the final frame index. If you animate or step forward through the video, the markers follow along the lines of the analysis.
