Edit the Marker Attributes
Once a marker has been added to the marker list, use the following options to change its attributes.
  1. Select a marker from the list or from the graphics window, then choose from the following options.
    Fill marker symbol
    Fills in the marker dot to improve the view of the markers on the video.
    Marker color
    Click the color selector to display the color palette and change the marker's color.
    Traceline color
    Select a color from the palette to change the tracing line color.
    Traceline thickness
    From the drop-down menu, select the tracing line thickness type.
    Font icon
    Click the font icon to display the Font Selector dialog. From here, you can change the font type, style, and size.
  2. Click Apply.
