Prefix All Curves with an Iteration Identifier
  1. From the View menu, select Browsers > HyperWorks > Parameters to display the Parameters Browser.
  2. Right-click within the white space of the browser and select Expand All.
    The browser is expanded to show the entire contents of the session.
  3. Right-click on a curve and select Select All from the context menu.
  4. Activate the checkbox next to Name.
    A new row is added to the lower portion of the parameter table.
  5. Click the ellipse button, , next to the default curve name to display the More Options dialog.
  6. In the Name field, enter Run ID:.
  7. Change Value type to Prefix.
  8. Change Default value to Run 1.
  9. Click OK.
  10. Click Save, , to save the script template.
  11. Click OK.
  12. From the Reports toolbar, click the Open Report Panel icon, , to display the Flexible Report Templates dialog.
  13. In the Run ID field, enter Run 2.
  14. Click Apply.
    The session is recreated and all curve names have Run 2 at the start of their name.
