Context Menu
Right-click on any parameter in the parameter table, or in the white space within the browser, to display additional options.
Collapse All
If you select Collapse All in the white space of the browser, this option collapses all items in the browser tree. If you have a particular entity or folder selected in the browser and select Collapse All, then this option only collapses the items beneath the currently selected entity or folder.
Expand All
If you select Expand All in the white space of the browser, this option expands all items in the browser tree. If you have a particular entity or folder selected in the browser and select Expand All, then this option only expands the items beneath the currently selected entity or folder.
Select All
For the entity type currently selected, this option selects all items of that type in the browser.
Select All in Page
For the entity type currently selected, this option selects all items of that type in the current page.
Select All in Window
For the entity type currently selected, this option selects all items of that type in the current window.
Show/Hide Filter
Displays or hides the filter options at the top of the browser.
The following context menu options are displayed when you right-click on an automation script parameter at the bottom of the browser.
Remove Parameter
Deletes the parameter.
Merge
If two or more parameters are selected, this option merges them into one automation script parameter.
Show in Tree
Highlights and displays the location of the selected parameter in the browser tree.
Note: If a parameter has been selected for multiple attributes, the Show in Tree option automatically highlights and displays the location of the selected parameter for each selected attribute.
