Define Parameters
There are three types of parameters that can be defined: window, value, and text modifying.
You can select properties across different objects and applications if the property names are exact. For example, a parameter can be shared by a property named “Text” on the contour legend header and note in HyperView. Similarly, a parameter named “Color” can be shared by the plot legend and a note in HyperGraph.
Window Parameters
- Background Color
- Frame Color
- GridLine Color
- ZeroLine Color
Value Parameters
Text Modifying Parameters
