pulIMacro RemoveParameter
Removes the specified parameter from the macro.
pulIMacro RemoveParameter index
HyperWorks Tcl Modify
This command removes the parameter with the given index from the macro.
index
The index of the parameter to be pasted. Must be a positive integer.
hwi GetSessionHandle sess
sess GetClientManagerHandle pm plot
pm GetMacroHandle macro 1
macro AddParameter “Parameter 1”
macro RemoveParameter 1
Returns 3 if there is an invalid macro handle.
Returns 4 if the index is less than 0 or greater than the number of parameters in the current macro.
Keywords
HyperWorks
Macro
Tcl
