pltIDatum GetName
Gets the title of the datum.
pltIDatum_handle GetName
HyperWorks Tcl Query
Returns the title of the datum.
None.
Gets the associated axis for the datum.
Sets the associated complex area for the datum line. Returns the complex component axis in which the datum line is located.
Gets the datum’s context menu parameter.
Gets a handle to a hwIFont interface for the font of the datum.
Gets the datum’s index.
Gets the label (displayed text) of the datum.
Gets the label location of the datum.
Gets the line color of the datum.
Gets the line style of the datum.
Gets the line thickness of the datum.
Gets the position expression of the datum.
Gets the value (position) of the datum.
Gets the datum’s type.
Gets whether the datum is displayed or hidden.
Sets the associated axis for the datum.
Sets the label (displayed text) of the datum.
Sets the label location for the datum.
Sets the line style of the datum.
Sets the line thickness of the datum.
Sets the title of the datum.
Sets the value (position) of the datum.
Sets whether the datum is displayed or hidden.
ON THIS PAGE
None.
ON THIS PAGE
